Re: aq125a impeller...maybe?
my 1983 bayliner with a aq125a has an issue when i have it out of water with the suction cup ears on the outdrive it over heats and steams up 200+. I shut it down before it gets hotter. but when it is in the river it runs ok like 180 deg F and holds steady. does the impeller need replaced or should I just get a test barrel for out of water testing?
I've never tried muffs on mine, only a barrel so I cant speak to which one is better......
However, there is an elbow fitting on the outdrive, near the top under the bellows. They are notorious for rotting out and developing leaks. The water drawn thru the muffs has to pass through this elbow to get to your seawater pump. The point is just sitting in the river and running, this elbow sits just under the water so even if it is rotted and leaking you wont get an overheat.
Until that is, you drive fast for some period of time, then the fitting will come out of the water....thats the way a bad elbow will most often show up, people will say, it will idle and go slow all day without overheating but when you get on it it overheats.
In your case it may be that on the muffs the leaky elbow is getting you but sitting in the river its not.
