I just got back from a weekend on the colorado river. Had a good time and all but my boat was overheating anytime I got the rpms over 2500. Once over 2500 the temps would just climb and climb, no difference if I was at 3000 or redlined at 5000 rpm. Then I'd back it off to 2000 and it would cool back off pretty quick to its normal temp of 180.
First thought was an airleak in the leg. But I just replaced the water connection and hose on the intermediate while I replaced the bellows. I noticed that it would overheat both on plane and at 2800 rpm not on plane. I'm not sure of the water level on the drive at that lower speed though. When I changed the water connection, I noticed the tube's plastic bushing below was breaking apart, I'm wondering if this could be a source of an airleak.
Then I decided to pull the impeller (didn't change it this year). It looked pretty darn good with just a little wear on the fins but nice and flexible.
I talked to a local boat service shop owner while out there and he said something I didn't think of and was wondering if this is in fact a 'known' symptom. Anyway, he said he's seen it several times before, the high rpm's get the raw water pump shaft deflecting and causes an air leak on the shaft seal right on the back of the water pump. He suggested a pump repair kit with a new shaft, seal, and bushing. He knew he didn't even have one on hand so it's not like he was just trying to sell me parts or something.
I took the pump apart and inspected the shaft and seal. The shaft has a little bit of a ridge cut into it from the seal and the seal had a little wear aside from looking pretty darn good. I did notice that I could deflect the shaft a little by hand, not enough to make a gap between the seal, but it moved a tad. I ended up using a little fine grit steel wool and smoothed out the shaft a little. It actually seemed to inprove by about 400 rpm until it started overheating. (first day I had to back off all the way down to 2000-2100 rpm, day two I could do 24-2500rpm)
So to sum this thing up, I probably need to do both repairs. The water pump is easy but costs $100 for parts, and it sucks to spend a hundred if you don't have too. The bushing in the leg is $10, but is going to be a real PITA to do. I just had the upper apart and don't want to press out the tube for a questionable fix.
Thanks for reading my wall of text, if you have any insight on this problem or tips for either repair option I'd love to hear it.
