TralierTrash
- Joined
- Jun 21, 2007
- 12
After registering on the site I realized that I had spelled my user name/screen name wrong. Sorry
I hope that I'm not out of line by making my first post a question. I've been reading these posts for weeks and have had some great success making repairs based on other threads.
However, I'm hoping to find some specific help on two problems that I'm having, or think that I'm having.
So far the repairs/maintenence that have been done:
Impeller
Thermostat
points
rotor
plugs
wires
coil
carb rebuild
new v belt
fresh fuel
Now on to the issues:
1) Oil pressure. What should the idle and operating oil pressure of an AQ125A be?
2) Again, assuming that the gauge works properly I'm finding that my water temp climbs over 200 idling in the driveway. I do have a freshwater hose hooked up to the motor. I've replaced the impeller, flushed the cooling system multiple times, I've even replaced the thermostat. I'm getting plenty of water moving through from the hose. When out on the water under cruise or load the temp quickly climbs to 250 or so and does not come back down.
Thoughts, suggestions and diagnoses are certainly appreciated.
Impeller
Thermostat
points
rotor
plugs
wires
coil
carb rebuild
new v belt
fresh fuel
