BAron Sportsman
- Joined
- Apr 21, 2011
- 17
I have a Volvo AQ130 with a 280 drive and having problems getting a simple answer from anywhere. The leg travels up and down ok, but on the travel down, it gets almost to the bottom and then drops suddenly. It's not a big drop and doesn't drop all the way down, but it drops a short distance just the same.
I had it to a Marine shop and they replaced the worm drive in the lift drive as part of a $900 service and they said it worked fine. I got it home and expected it was now finally fixed and proceeded to tilt the leg down and "Bang", It dropped at the same point as it always does and has still continued to do it every time since. I haven't removed the unit as yet to have a look at it myself, but it's almost like a tooth or two missing of a gear?
I don't want to have to replace the whole unit if I can help it, becasue they are quite expensive. Surely this problem is consistent with a part inside that simply needs replacing but know one will tell me the answer. I can't be the first person ever to have had this problem.
I have looked at an exploded view of one of these complete lift drive units and there is parts everywhere and clueless where to start. If I just knew what part is faulty, I'll simply removed the unit, pull it apart, replace the faulty part and put it back together again.
Can anyone give me some clues,,,,,Please....?
Thanks in advance.
Thanks in advance.
