AQ130D fuel pump
ranger55
Hello, back again. does any know where I can get a fuel pump for my AQ 130 D motor, or a rebuild kit for the pump I have. I believe i am having fuel related problems, but not sure, motor bogs down at about 3000 rpm. It has the weber conversion kit and runs fine up to 3000. I have replaced fuel lines, filter, and cleaned the screens in the carb and fuel pump. I am going to put a vac. gage on next week to check the pressure. However, thought I would start checking into a new fuel pump just in case.
Thanks
Sorry to here about Don S, Big loss...
jerryjerry05
Re: AQ130D fuel pump
Usually a Volvo pumps not re-buildable.
Start with you in the US??Where? Profile,Location?
Ethanol is messing with older hoses.
It causes them to delaminate and can collapse.
Tank to pump,gas line,new?
Then check the gas tank vent line.It can get clogged with wasp nests.
Your motor could have a solid gas line or a rubber hose going to the carbs.
It could be getting soft(ethanol).
