Haven't been able to check the voltage yet because of work. But over the weekend I tested the motor on the battery and it does spin. Had the motor off of the device and hooked it to the leads and got nothing from the relays forward or backward. I did hear clicking though. Don't know if this helps but I do have an intermittent issue with the bilge pump and navigation lights. Trying to track the issue down.
On another note I just got done resealing the outdrive. All new seals on the water pipes, rebuilt sea water pump and still it over heats. So I took the cap off the strainer and I'm definitely getting water up to the strainer using a bucket of water on the leg. Tested flow through the exhaust and that's clogged up so I ordered a new exhaust manifold. Also installed new shift and throttle cables. This boat bring a whole new meaning to break out another thousand. Lol
Thank you for all of your help!
