AQ131D point & plug Gap
user-name
I've searched for what seams like days. I'm getting numbers that dont make sense.
But then again Im a GM guy 19 for the points 32 for the plugs.
The volvo Im finding
40 points dont seam right
32 plugs OK Ill buy that.
Thank you
Don S
Re: AQ131D point & plug Gap
.40 is mm, which is .016 in.
user-name
Thank you Don
Now the 0.157 makes sense
.016 & .032 it will be
RogersJetboat454
Should also consider checking your engines dwell when you get it buttoned back up. ;)
user-name
At this point of time all I have is the download of the Operators manual. ((((Paperback manual is in the mail))))) I cant seam to find the dwell angle in there.
Don S
Odd they don't have that in the owners manual, but it's 62?3?. Best to keep it as close to 62 or 63 as possible, they start best in that range. Without a choke, you need all the help you can get.
Info is from the engines service manual found here.
user-name
Thanks again Don
Your A life saver my Western Washington Neighbor
Don S
Yeah, you aren't that far from where I live now, I used to be a lot closer when I lived in Anacortes. The SJ Islands is where I worked and played.
user-name
Your that far away you can adjust my dwell. Been a long time for me since i did that style of dist cap. GM window easy.
Thank you for that manual.
It states the
(points .017)
(Plugs .028)
(dwell 62 + or - 3)
Owners Manual
points .157
plugs .032
dwell MIA
I think Ill go with the .028 on the plugs
Don S
It states the points .017 Plugs .028 dwell 62 + or - 3
Onwers Manual points .157 plugs .032 dwell MIA
I'm not sure what you are reading, but the service manual does NOT say .017 plug gap, it does say .7 mm gap (mm again not inches) and .7mm is basically .028 INCHES.
Nothing anywhere says anything about .032 dwell. There is a spot that shows 32?-36? of advance timing at 4200 rpm, but that has nothing to do with dwell.
attachment.php
user-name
OOOOPPPPPPSSSSS
I should have broke up the post better Fixed
And thanks for the correction on the points I hit the wrong button
Don S
Point gap is only a starting point so you can then adjust the points per the dwell setting. Start at .016 or .017 (either one will work) and then run the engine, opening or closing the points to get the dwell to 62 or 63?.
