AQ145A oil cooler .raw water in oil and out leg
sprogg&fin
this is almost a continuous of last post , had a carb problem , fixed it and was running the motor and noticed a raw water leak at the oil cooler so I undid the bolt and fixed the leak(was the raw water pipes at each end of cooler) , started the motor and now I have raw water in my oil and going out the leg and lots, I know my headgasket it not faulty , I also checked my plugs and they are fine. before I messed with the oil cooler and fixed the leak I had no water in my oil, did I not seat the seals properly?, please help any info would be appreciated
sprogg&fin
Re: AQ145A oil cooler .raw water in oil and out leg
easy fix, as I found in my research , gasket between engine and oil cooler needs replacement for anyone else that needs to know, a couple of oil changes and filter , good to go once fixed, don't know if my last post went throu
sprogg&fin
Easy fix , the last person to work on this had no clue, the oil cooler was on basiclly hand tight at best and was why I had water and oil everywhere, my first time working on a I/O , runs good but does anybody know a good link, to link and sync my motor, runs well at idle and can get the revs up good but it does not like to hold a constant rpm?
