AQ150B PDS bearing part number?
Skidude17
After a bunch of research, I finally found the Volvo nomenclature for my engine. It's an AQ150B with a 270 drive. The engine is a Buick 225 V6 oddfire. There is only one other post on this entire forum that mentions the AQ150 that I can find, but it's backed up by a couple of European websites.
I need to replace the PDS bearing and associated seals. I'm pretty sure it only needs one bearing even though it is a 6 cylinder. There is only one place on the shaft and in the flywheel housing that I can see for one.
Does anyone know where I can find an exploded diagram with a parts list? I can't find one on iboats.
Pics of the PDS and flywheel housing are attached.
nothing shows up on volvopentastore.com when I looked, you may have to do some cross checking with other models such as the AQ130
