Re: Aq170a won't start
thx guys, I've never done a full tune up. what does this entail ? should i take it to a professional? what should i expect to pay ?
Do you know how to do a compression test? Do you know how to use a dwell meter? timing light? shop tach? how to adjust dwell, timing, and idle mixture? Are you mechanically inclined, more than knowing the difference between a socket and a screwdriver?
If the answer to most of them is no, then find a shop
Ask them how much they charge. A lot depends on access to what needs done, and shop rates. Not many shops will even touch the old 170's.
Are you using the throttle only button to pump the throttle and give it throttle while cranking or just trying to start in neutral?
There is tune up information in the stickies (first threads in this forum) on points systems.
