Ok, I know this subject has been touched upon before, but wanted everyone's input. I've tried the rabbit ear approach to run the engine in the driveway, but the water intake appears to be right on the edge of the outdrive so I can't get the old rabbit method to seal tightly around the intake slots. So, the next step was the old outdrive in a big bucket approach. Via this method, I've concluded that the impeller can't take in any water. The impeller appears new. If've take the hoses off on the inside of the engine, and let it take in water from a bucket, via this method, it takes in water just fine, engine runs cool (130 or so). Is this just the law of gravity, that is, the water is just to low to take in? The water is about an inch or so above the intake slots, or have I just proven that I possibly have air leaks in the outdrive somewhere? Obviously when the boat is in the water, the water will be much higher. This is also my next step, to put it in the water and simply see what happens, just have to get a few other things fixed first
