Hi,<br /><br />I'm having a lot problems with my 2 AQ171 engines. Two years ago the timing belt on both engines lost some teeth a few weeks apart. The result was 1 piston and 22 valves down the drain.<br />I repaired that myself and now I find myself in the same situation again with 1 motor, I suspect the other will follow shortly...<br />Does someone know what is causing this?<br />The guy at the shop suggested a leak at the rawwater pumps, which was the case 2 years ago, but since then I closely wath these pumps and change all the seals every year, the belt is dry now.<br />Could it have something to do with the belt tensioner?<br /><br />I'm totally in the dark about this one and I don't trust those engines anymore...<br /><br />Thanks for your input.
