Fire Escape
- Joined
- Jul 8, 2009
- 16
Last time out I "toasted" my exhaust hoses. Replaced them and the riser gaskets, (exhaust manifold and risers are clear, barely any interior passage surface rust). I suspected a sea water pump problem, removed and examined impeller, looks good. Replaced and sealed cover with RTV. I also put 2 clear hoses on the thermostat housing to exhaust manifolds so I could verify the water flow. At idle, the hoses were half full of water and I could hold my hand on the risers, engine temperature was normal, 160, (I had previously tested the thermostat in a pan of water on the stove). After a half hour of idleing at the dock, I went for a quick spin and then looked back to see that the hoses were completely dry! Let everything cool down at the dock, restarted the engine and got NO flow to the exhaust manifolds. Could I have enough suction at the pump to collapse the "S" hose from the outdrive to the transom shield? Or an impeller that is freewheeling on the shaft? I can't see anything on the inlet of the outdrive, (plastic or seaweed) and am looking for an air tank to blow out the line from the pump intake to the outdrive to verify that it's not obstructed. Any ideas? HELP!
