On my 1990 AQ231A, where does the thermostat go? Does it go under the housing gasket just like a car or go up inside the housing where there is a groove casted into the housing for the rubber gasket to fit around the thermostat itself? Reason I ask is because if I was to put the thermostat up inside the housing wouldn't that keep water from flowing through the exhaust while the engine warms up? If placing the thermostat under the gasket, it would still allow water to flow through the manifolds. Isn't water flowing through the manifolds at all times what I want?? When I bought the boat I was told it didn't have a thermostat. I take off the housing and it had a 195 degree flipping around in the housing. Somebody obviously tried putting a automotive thermostat in it and failed. I bought a 140 degree for it. Where is the correct location for the thermostat?
