aq231b block cracked
mfsb
Picked up nice 1988 Marathon Weekender that was not properly winterized. The engine block is cracked. I was wondering what year group of 305 engine to get for a donor block? Also have been interested in maybe getting a 350? Do I need to use the 305 heads or can I just get the proper cam grind and brass freeze plugs on a 350 and rebuild the rest normally? I have also seen several performance intakes used on ebay, would one help in a marine application? Seems like it would not. Thanks for any advice you can offer.
captmello
Re: aq231b block cracked
It sounds like you have the right Ideas. upgrade to the 350, using 350 heads, with the correct cam and brass plugs. Performance intake can be used in fresh water, I'm assuming its aluminum.
Welcome to iboats, BTW.
