AQ231B Impeller
bgc
Ensign
1988 AQ231B impeller for Sierra #18-3081/Volvo #875811 is not wide enough to fill the impeller cavity. Do I need Sierra # 18-3287/ Volvo # 876120?
Thank you
Don S
Re: AQ231B Impeller
I would bet that someone replaced the pump. Does it still have a pump with the thick base and long mounting bolts like the one shown below?
bgc
Ensign
Re: AQ231B Impeller
Don,
Its hard to get a picture with the fuel tank and the bulkhead but this is what I have. Thank you for any guidance.
bgc
Ensign
Re: AQ231B Impeller
I found a listing that has the 3368821 impeller at 31.5mm long? The Volvo site did not indicate the sizes.
It is possible I have a "Frankenmotor"...... The 876120 cross referenced the 8557222 stamped on the pump cover and is 50mm. On the VolvoPenta site it indicates "Fits Most Gas-V8-Older" Any thoughts?
bgc
Ensign
Re: AQ231B Impeller
The 876120 impeller did the trick.
