AQAD41A oli cooler mainteinance
vince59
perdita scambiatore olio (2) (816 x 612).jpgperdita scambiatore olio (2) (816 x 612).jpgperdita scambiatore olio (2) (816 x 612).jpg
after more than 100 hours I am doing some mainteinance. As you can see in the enclosed picture I had some salt water coming in from the oil coolerbut no problems at all. Do you have any tip or trick for this kind of job? Engine is a AQDA41A has anybody step-by-stepdismounting instructions? Thank youvery much for your helpul support!OIL COOLER
Don S
Re: AQAD41A oli cooler mainteinance
For one thing, you need to get rid of all that teflon tape on the anode plug. It has to be able to make a ground, and it look like you have several wraps of tape there that will prevent the plug from making a good ground.
vince59
Thanks Don, good to know...so what should I use for the plug? What is your opinion about the leakage? where is the salt water coming from...o-ring? any suggestion for disassembling?
vince59
so now advise form experts???
