Well, NAPA is closed for the day, so on to another 'project...'<br /><br />My sister's tri-hull now sports what appears to be a circa 1990 Rude 90HP. There was previously a Chrysler 85 that had 'sat too long' on the boat, and had seized up.<br /><br />The Chrysler had a tach made by Aqua Meter which is still mounted on the boat. The tach has two wires: grey and white I believe.<br /><br />When the marina installed the Rude and controls, they did not re-connect the tach. <br /><br />Would there likely have been a sending unit on that Chrysler (my sister still has it)? Or would the tach likely go to ground and a cylinder?<br /><br />If a sending unit is required, would anyone know a best source for such a part - I'd rather NOT buy a whole new tach if I can help it and a sending unit is cheap.
<br /><br />Thanks again!<br />Dan
