Re: aquafiend overheat problem
yes new water pump kit ,no melt on housing<br />with the lower unit off the engine and muffs on the lower unit ... the water pump leaks from the driveshaft hole ... maybe this wont happen when the pump is going ? , the oring is underneath the metal housing .. <br />is this normal ?<br /><br />it doesnt leak from around the pump. i will remove the water pump again and clean the rubber dam, brand new thermostats, got new pressure control grommets( valve is under thermostat housing)<br />can the heads be removed without lifting the powerhead off ?<br />---<br />the engine has been siting in the back of a truck for about 4 yrs i think, since the shift rod rotted and owner got new engine ... now i got the engine and all of its problems ;... he said it never overheated when he ran it .
