Re: Arc weld a cracked block with nikel rods?
Well I had the crack in the galley arc welded with the nikel, he said he knew to cool slowly and peen. He was confident it would hold, I did smear it over with jb weld for insurance. There was also a crack on the water jacket of the exhaust mani, welded that too. Another crack on the lower portion of the block, he could not get at that one, so I sanded it cleaned and jb welded it. My gosh what the heck did the previous owner do to this boat! Freeze cracks, heat cracks, I wonder if there are more cracks I cant see?!?! Damn I hope this works! I am going to put it all back together before the weekend, drain the oil 2-3 times, get it clean and try it out!
Can someone tell me the best product to clean out the inside of the galley, looks a lil dirty in there, must be gasket pieces, metal shavings and what not, doesnt look to bad, it needs washed & cleaned out for sure. Also, while I have the manifolds and risers off, they appear to be quite rusty inside the water jackets, should I clean those up too and what to use on them? Thanks for the help guys!
