Are a 16 amp and 9 amp stator interchangeable???
beretta5spd
This is the part my boat calls for:
http://www.iboats.com/mall/partfind...d_poid=334748&gd_row=140&**********=059683116
I would like to know if a 16 amp will work with the rectifier designed for the
9 amp stator or if the 16 amp requires a voltage regulator. I would like
to replace my 9 amp with a 16 amp if possible, like this one:
http://www.iboats.com/mall/partfind...d_poid=334749&gd_row=175&**********=059683116
Thanks for your help in advance
Laddies
Banned
Re: Are a 16 amp and 9 amp stator interchangeable???
The 16 amp stator will work with the rectifier for a 9 amp system, however it will usually over charge the battery so a 16 amp regulator is recommended
