Are all drain plugs the same?
KD4UPL
Some of the blue plastic drain plugs are leaking. I probably just need the o-ring but I can't seem to find that available as a part. The whole blue plastic "wing-nut" drain plugs are available. I see them from 3 different manufacturers ranging in price from about $3 each to about $9 each. Sierra, Mallory, etc. Are they all the same? Can you just get the O-ring? Anybody know the size?
Ayuh,..... As far as I know, Yes, they're all 1/2"- 13,......
Take yer plug to yer local hardware store, 'n ask for their O-ring Index,.......
It's just a plain ole o-ring,....
Bt Doctur
unless its the water dist housing that leaking, a cracked housing not the O ring
You can use a 1/2-13 bolt and an o-ring from the hardware store
AShipShow
Orings pretty much all fall under the category of "off the shelf"... it's a commodity and if you can design a part that uses a standard o ring for $0.002 in volume or make a custom mold tool to produce 5k pieces a year at @0.50, they will always use option 1... all that to say, it's almost certainly a standard oring
crazy charlie
Never liked the blue plastic.Replace with brass elbow which is what THEY USED TO USE.Charlie
achris
More fish than mountain goat
Never had a problem with the blue plastic. 13 years on, still nothing wrong with them, never leaked. Don't know what the fuss is about really.
The 'O' ring is a very standard 2-014.... (1/2"id x 1/16"cs)
Chris......
KD4UPL
Chris......
Thanks for confirming that thickness dimension. I got some at the hardware store, trying to match by eye and that's exactly what they are. My eyes must be working.
achris
... My eyes must be working.
Lucky you. I have eye surgery scheduled for June. Both eyes, new lenses (I have monocular triplopia in the left and monocular diplopia in the right)... Should be fun. :eek:
Chris.......
