Re: Are any outboards better for salt water than others?
Really no OB is just primed and painted. They all have about 7 layers of special primers, and paints. The foundation aluminum on OB's are strong and the parts are made to combat both water types. ALL METAL WILL CORRODE WITH SALT WATER!!!! Whether is says "ocean runner", or "Salt Water series" it's still pretty much the same as everyone else. Maybe a few more stainless parts. All OB's have zinc annodes also. Run, rinse and flush with fresh water after every salt water use and you will ok. Also, if your going to be going in salt often, good idea to coat the powerhead and electrical parts with WD-40, and Keep all pivot points and grease fittings full of marine grade grease.
