Re: Are my reed valves bad?
I guess I would have to say, I have been working on OMC engines since about 1962, as that was the first year I went to Evinrude service school in Milwaukee, Wis. Outboard engine repair has never been my first line of work, I was a full time firefighter, so it was always my second job, can I claim 43 years here? Changing reeds is what I would call a band-aid fix. They are seldom the cause of a poor engine running problem unless they are broken, They are a spring steel, with a positive stop, so they are almost impossibble to bend out of shape. The Boyesen reed is a definite improvement because they respond instantly to any positive, or negative impulse simply because they are softer, and lighter. They also flow wide open per engine demand because of the no stop feature. A factory installed reed will respond to a very small impulse, look elsewhere for the problem. If your engine responded to Boyesen reeds, what would unstuck rings, and proper tune-up do? Did you use a set of wire guages to check the jet size when rebuilding the carbs, after 20 years, I did.
