It is in the 50's here in Houston. I heated my garage to about 65 and applied waxed gelcoat with a little extra catalyst to the hatches of my boat. After two days it is still tacky on top and I can take the gelcoat off with an acetone soaked rag. My resin supplier said the gelcoat did not cure properly probably due to the temp. He said that I should be able to run an acetone rag over the surface and remove wax only and no gelcoat after a day. I called a local shop who was careful not to reveal any trade secrets but implied that different techniqes and different products, one of which was different catalyst, could be used in the gelcoat to get it to cure in the cold temps as he does it all the time.
Is my supplier correct that the gelcoat probably did not cure and that it should not wipe off with acetone after a day?
Are there different catalysts for cold weather?
Can someone tell me any other tricks or clue me in on other additives I might consider using so I can finish now rather than wait till summer?
