alesserfate
- Joined
- May 27, 2009
- 37
Hi there,
I have a Volvo Penta 260A (GM 350 V8) with raw water cooling that I am converting to closed cooling, block only. (fresh water cooling however you wanna call it, I call it closed since fresh water is misleading).
As I was inspecting my engine I realized the manifolds are aftermarket made by BARR and that there is a second fitting on the back of them that's not hooked up.
My question is... are these aftermarket manifolds capable of being used for closed cooling - water goes in front fitting and out the back one... presuming I get some kind of a riser with a separate inlet fitting to dump the raw water that comes out of the heat exchanger. If they are capable then I will be integrating them into my closed cooling circuit.
Here are some pics.
Thanks in advance and hope to hear some input!
Here are some pics.
