Heavens....just dropped a wad on inserting the copper tube properly back in to the power head, first 5 times out ran beuatiful spraying more water than i thought would come out....last time out...NO water, and I mean no water coming out. Replaced water pump housing/imp et al prior to copper tube re-installation.
Now here is my pea-brain working......Is it possible since the amount of water being blown out actually created/exposed a clog in the thermostat itself. Or in other words, can a stuck/siezed t-stat block passage?
If no, I guess it could be just bad luck with the new merc imp and it failed already completely, possibly (i guess) the pin in driveshaft broke, possibly the 4 bolts holding the housing in have backed off or something creating no contact between pin and imp., possibly a clog elsewhere But Where?.
Tests I can think of...
1. force muffs (not running motor) to see if water comes out from pee holes removing all above questions.
2. hose to copper tube, see if water pushes out pee holes
3. test back and waist muscles as I remove the whole shebang and insert a new yamaha...im getting close!!!
