Ark Ark! help with SEALS!
BigBobsBigBobbingBogBoat
Ok...no not the "ark ark!" kind...
What do you guys use to lube or grease these when you replace em in like the upper gearcase and such?
Do you reccomend titelock on all the bolts for an outdrive when reassembling?
Bob
Re: Ark Ark! help with SEALS!
Ayuh,... I use a finger full of whatever grease is in the nearest greasegun for prelube...
I can't feature lock-titin' anything either...
Aluminum, 'n bolts tend to grow together, all by themselves...
Maybe a dab of Perfect Seal to slow that from happenin'...
