Sunken Ship
- Joined
- Jun 19, 2014
- 252
When I reduced the throttle from 100% it hangs at around 30% where it appears to be binding on something. I adjusted the cut-out switch as I thought this was binding on the switch as it came back into contact with the armature plate. I made a video showing how the armature plate is jumping up, but I don't know if this is normal or not. Does anyone know if the plate is supposed to jump up like it is doing in this video?
I did disconnect the throttle cable at the motor and this cable is very smooth at the controls when disconnected. I lubed the entire motor with fresh grease, included the two fittings specifically for the throttle rotation.
