Arrrgghh wrong gasket - 225/1993
swist
This should go in stupidolts human tricks....<br /> <br />Replacing tstats for the first time. Working with boat in water engine tilted up and sitting on transom - very good accessibility except view is mostly from the top. Take out the 4 bolts. Cover stuck to gasket. Expected. Stick screwdriver in and whack THE DAMN CYLINDER HEAD COVER GASKET - ONE @#@$^&&* GASKET TOO LOW. Took out a good chunk - can see it bent and mangled looking through tstat seat. The drawing in Clymer's doesn't really give a fair indication of how thin the tstat housing is but that's no excuse for not just plain looking.<br /><br />Lucky local dealer had cover gasket in stock. That job took forever - has to be the most complex gasket I have ever seen and cleaning off residue took forever. Not to mention cleaning crud off 22 bolts.<br /><br />It was interesting to see only minor corrosion in all the water passages after 11 yrs in salt, but no I did not pull this idiocy to inspect the water passages....
rodbolt
Re: Arrrgghh wrong gasket - 225/1993
hello<br /> why did you remove the water cover? and yes the gaskets do stick hard. next time use a 3m scotch brite pad on a drill. whisks it right off.<br /> good luck and keep posting
swist
Because I took a piece out of the gasket and was sure I would have a water leak.
rodbolt
yep you would have:) :) . but now you have the great experience:). I hate dealing with them tiny saltwater fastners. glad none broke<br /> good luck and keep posting
