Last week I bought a 2010 Tohatsu 9.8 four stroke. Model Number is: MFS9 8A3
I bought it last Friday. Tested it with the seller and it all looked great.
Put fresh gas and Stabil Marine in it. Last Saturday it ran great. I had it out for about 3 hours or so. Perfect. No issues. When I stopped I disconnected the gas line and let it run until it died.
I stored it in my garage.
Today I went to take it out. Re-attached the fuel line, pumped the bulb maybe 3 times and tried to start it. I stupidly did not choke it. After it would not start after a bunch of pulls I realized that I did not have the choke pulled. Thinking I flooded it, I waited for about 20 min. Tried again with no luck. Changed the spark plugs. Still no luck.
I have checked the spark and I have spark with both plugs. If I pump the bulb gas will come out of the bottom of the carb so I know it is getting fuel. The red oil light will go on as I pull.
If it was an issue with the kill switch I would not get spark right?
If I did flood it, wouldn't the issue resolve within 30 minutes or so?
What should my next steps be? Should I just bring it to a dealer?
I am really bummed. I did a lot of research and saved for a long time to get this motor and thought they were reliable and a solid buy.....
Any help is much appreciated!
Stroth
Stroth
