As usual simple floor gone bad
ColdFire
Ok as normal what was thought to be a simple floor replacement on my 1987 Astroglass fish and ski 178 has grown. I have two stringers rotted on one side and as I tore into the beast I have found the transom has started to go. After much cussing bleeding and a few sacrificial animals to the gods... :D <br />I have finally split the seal between the transom and the top shell. Now after much reading and surfing, I am wondering. While I have this thing all the way down should I replace the good stringers with new wood while I am at it? Also after perusing a few of the many epoxy web sites I would like your opinions on whether it is necessary to use roving on the transom replacement or not. A couple of sites say yes and a couple say no you don’t have to with an epoxy repair. I am planning on using 2 layers of 4oz cloth for the new floor and 8oz tape for the stringers, could I do better on my cloth weights. also what is the best way to estimate how much epoxy is needed, I have seen folks throw out the number of oz that a set amount of epoxy will wet out. As usual with the net I have found too much information and I am starting to second guess my self.
Indymike
Re: As usual simple floor gone bad
Hello ColdFire. I'm in the middle of a resto myself. I would go the whole nine yards while you're in there. That little gremlin in your head head will bug you to no end if you don't. <br /><br />As far as glass cloth I am using 1708 biax on mine to tie everything together and I am pleased with the results thus far. From reading the many other project chronicles here I think 10 gals. is a pretty good guess for the epoxy.<br /><br />Like you I was struggling with estimating the amount of epoxy to buy so I bought 6 gals. to start and from that I think I got a pretty good feel for what it will take to finish.<br /><br />Good luck
JasonJ
Just replace it all. You'll sleep better at night....
mellowyellow
if not now, when?<br />how much extra work are we talking about really?
ColdFire
That is what I was thinking but you know how easy it is to try to take the shortcut. But with what looks like another good winter storm headed our way, it is a good time to see how much damage I can do :D
