Just changed impeller on 1995 130 hp Johnson.Still,water only dribbles out(pisser).If I disconnect small hose from block to aspirator(?) at the aspirator it shoots out like hole above and foward of water intake when earmuffs applied.But when I reconnect the hose it just dribbles out.Aspirator is called "pump" in manual.Is it supposed to have alot of restriction or is it supposed to be clear?<br />P.S.-1st boat,just bought last year.Also,1st impeller change-took 11/2-2hrs.Simple job-next time should take less than 1 hr. thanks to info on this site.
