Assembling reed plate
tritak
Hello, I have a 1976 Johnson 70. Model# 70EL76D<br /><br />I have been trying to resolve an idling and full throttle issue. I have cleaned and rebuilt carbs,changed fuel pump,changed plugs,checked compression and made sure all cylinders were firing.I am now in the process of replacing reed boxes and reeds. MY question is - Do I need to put any gasket sealer on the new intake manifold gaskets? And if so, Can I use HI TACK Permatex? I have a Seloc manual but it doesn't say wether to use sealer or not. Thanks for any advice!
Dhadley
Re: Assembling reed plate
Welcome!!<br /><br />You can use Hi Tack if you like.
tritak
Thanks Dhadley! I also have another question, before I took the old reeds out I noticed some fuel sitting in the bottom set . Is this normal? Not alot of fuel just a little. Thanks!
Dhadley
It could be normal. Hard to say without looking. There should not be much at all though.
