Ok gents heres the story,
got a 140 merc 1984ish been running well since i had it rebuilt up 3 years ago. Yesterday on the water ran fine all day but then later in the day i started hearing a metal clanking sound (almost like something was bouncing around inside) and anything over about 2200rpm would set this noise off. I cruised back to dock at 2k rpm no issues ran great.
Fast forward to today, pulled the valve cover today and round cyl 4 lifter was crooked sideways, push rod and seat were fine. reseated the lifter and its now straight. Then I moved on to compression test.
cyl 4 100ps (bent lifter cyl)
cyl 3 60psi
cyl 2 50-60 psi
cyl 1 50-60 psi
I dont get why 3 cylinders are showing such low compression while 4 is fine and showed signs of a issue. Are my rings shot? this was a dry test. I didnt move on to wet test due to the low numbers to start.
Anything else I could be missing thats easier then a full tear down?
The oil looked amazing, no build ups or anything funny with pasages and valves. I thought maybe my compression tester was acting up but the first one we tested came out normal. Just not sure what i should look into next
appreciate the time guys and thanks
cyl 3 60psi
cyl 2 50-60 psi
cyl 1 50-60 psi
