dickenscpa
- Joined
- Jun 11, 2007
- 23
I'll try to be as thorough as possible so as to give you the best info I can, sorry if this is long.
I bought a 14' fiberglass tri-hull with a 1973 Mercury 402 40HP outboard. Had to keep priming the bulb to keep it running. It would get up and kinda go, but not what I'd call plane. Did a lot of research on this board and bought a manual and rebuilt the fuel pump, not much better. Cleaned and rebuilt the carb. It's a 2 cyl and only 1 carb.
About a week ago I was working on it and didn't button the cowling back up. Came home from office 7/3/07 was in a hurry to fish so I buttoned it up quick and forgot to put the boot back on the top plug. Ran like crap. Did a little maintenance on the water and put the plug wire back on. It feels like it's run on 25% power every since. I have to prime the bulb and put the warm up lever half way up now just to get it to start. Have to leave it there to put it in gear or it dies. Pumping the bulb doesn't help anymore.
Here's what I've done so far:
1)New fuel, fuel tank, fuel line/bulb
2)Rebuilt fuel pump
3)Rebuilt and cleaned carb (Wasn't that dirty)
4)Checked compression (Top cyl 132 bottom was 150)
5)Spark checked out fine (In driveway and under load)
I don't know what else to do? Compression, fuel and spark, what's left? With the warm up lever half way and full throttle, I might get up to 8mph if I paddle at the same time.LOL!
TIA for the help!
I also changed the oil in LU. Didn't look to be water in the LU and I drained it all and pumped new in.
2)Rebuilt fuel pump
TIA for the help!
