chevysford
- Joined
- Feb 4, 2023
- 17
I posted awhile ago about this tower of power that has been giving me a lot of trouble and the journey. Fast forward to now and I have brought the boat to a mechanic and he didn’t even look at it after having it almost 2 months. So I found a cheap boat with a mariner 115 on it and I robbed the parts I needed for mine which I assumed was my carbs. Swapped all three and some other miscellaneous parts I was missing and voila- she ran even better! Reved easy on muffs and I thought I finally had her. I then brought her down to the water and the same thing happened that happened before. I took off from the ramp and she died about a half mile from it. Wouldn’t start back up, acted like she wasn’t getting fuel again. After about 20 minutes of floating, I adjusted the idle cable way up and was able to get her running back to shore extremely slow. I got her to a pier and started messing with air fuel mixture screws. Set them to where the engine actually responded again and went back out from the launch. Ran ok, seemed a little slow, made a turn and she started bogging down again so I limped her back to the pier. Something’s I noticed this time that are different: 1. The exhaust ports near the pea hole have a lot of water and smoke spraying from them. 2. When I rev her up high I’d hear a weird noise and smoke appeared to back through the sparkplug wires to the top cdi.or the smoke was from under the cdi somewhere. Other things I did: I changed the water jacket gasket and stopped the leak I had coming from the sparkplugs. Please help
