At what point do you compress / collapse or cram impeller into housing?
gidds
I have seen numerous posts and read the manual regarding water pump / impeller replacement....I still don't understand on when / how you get the big-*** star into the smaller pump housing? What point is it done?
Any insight?
Thanks in advance!!!!!
ricksrster
Re: At what point do you compress / collapse or cram impeller into housing?
Slide the impeller onto the drive shaft so the key lines up with the slot in the impeller. Slide the housing down the drive shaft to meet the impeller. Rotate the drive shaft clockwise while pressing the housing over the impeller. Piece of cake!
MikDee
Banned
True, a piece of cake, but a little liquid dishwashing soap inside the housing, and on the impeller makes it easier.
domains
Banned
counter clock wise a impeller kills it. funny part i can't understand .guess after starting with no water had afect on beer buzz.
JUSTINTIME
counterclockwise will only kill a used impeller
i have spun new ones on counter clockwise, then spun the drive-shaft clockwise and the fins flop back
the whole reason is that to spin clockwise is that is the way the drive-shaft spins and flywheels, except on Honda's where the flywheel spins counterclockwise on some
Missxena
..Slide the housing down the drive shaft to meet the impeller. Rotate the drive shaft clockwise while pressing the housing over the impeller.
That's how I did it. I also put a light coat of grease
on the inside of the housing. Had no trouble - with this part
of the procedure anyway.
JUSTINTIME
soap is the best not grease
