rustyshakelford
- Joined
- Sep 5, 2008
- 6
Hi guys!
My name Brett and I was lucky enough to find this place today!
I have been reading thru a ton of threads thanks to the search feature but i havent found any that really nail my issues, so here goes...
I bought a pontoon boat to use for a business im doing part-time. he started the motor with the muffs on and it ran great...i shouldve lake tested it, but its to late now.
we get home and drop it in the water and as soon as i would put it into gear, it would die...
i talked to a friend of mine that is a paramedic and boat mechanic. he recommended having the carbs rebuilt. i bought everything and he cleaned them up. while he had it, he checked the cyclinder compression:
top: 120
middle:120
bottom: 110
the fuel is good and it has new fuel hoses and fittings.
I got the boat back and tried it again, same problem, but it did start quicker.
I called him and he came with me to the lake today and we worked on it! he double checked the jets and all were clear, adjusted the idle a bit and he told me we had a good spark, the plugs appear to be new.
it starts good and will idle like a champ, but as soon as you place it into gear, it dies. if you get it to idle in gear, it want to bog down and die. we were able to get it out into the lake and open it up. the boat is a 28' pontoon with about 1500 lbs of gear and people and the motor was stuggling, probably about 10-15 mph. im sure the prop had something to do with this but it was seriously underpowered. im not looking for a speed boat but dont want to constantly dog it to make headway.
i disassembled the fuel pump(diaphram)? and it appeared to work. the bowls are full of fuel so we pretty sure its getting fuel?? there are two new powerpacks and the other one is older. do youll have any ideas on what i can trouble shoot? it will run great on the muffs still but any load and it kills it. I need to get it up and running again asap for work but am also getting tired of spending countless dollars. i can also high idle it in the water and it sounds good. please throw out some suggestions if you have them!
thank
brett
top: 120
middle:120
bottom: 110
thank
brett
