ATF oil for trim / tilt
bijou22
Volvo Penta specify that you must use there ATF oil for topping up the trim/tilt sytem but it seems way over priced.
Does anyone know the oil specification, I am sure it can be bought cheaply from an auto store and do the same job?
imported_TheMan
Re: ATF oil for trim / tilt
ATF is pretty much ATF...
I think I used some Valvoline ATF in my pump system..
Maybe its more expensive in the UK since there are so many more manual transmissions.
bijou22
Does anyone the capacity of oil required to fill her up?
Don S
It's just standard Dextron ATF
You can also click here and download an owers manual for your engine. It has that info in it.
bijou22
Thanks Don, I can't find the amount of fluid required though.
Any ideas, the sytem is empty at the moment?
Ayuh,....
While I'm not exactly Sure,...
2 Quarts should be More than enough...
