The problem started when fishing, the RPMs dropped from 3600 to 1200 and then stalled. Later, checked the compression 85psi to 105 psi. I decided to decarb and rebuild the carbs. When I removed the front carburetor cover oil was laying in the bottom of the cover about 4oz. The VRO was disconnected at the beginning of the season and I mix my own 50-1. With the carburetor cover off and muffs on the water intake I started the motor and noticed puffs of air and fuel coming from all four carbs.<br />Not alot but enough to know something was wrong. My guess is that the timing is off. What else could it be? Is this motor easy to time? If that is my problem. Thank you
