generallee01
- Joined
- Jan 9, 2009
- 16
Hey guys, needs some help with ignition stuff. I purchased a used motor and just want to test run it on a dolly prior to putting it in the boat. It's an 89' 4.3 Mercruiser with thunderbolt IV ignition. I'm a good wrench, but boats are new to me. I'm not positive about the distributor/ igntion wiring. MY Dist has 3 leads running into it in a harness...white/green, white/red, and black. there is also another black wire on the bottom of the distributor, which i believe is a ground. White/red and white/green run to the ignition module. Not sure if the black is a ground or not, or goes to - on the dist?! I jumped 12v to the + of the coil and have no spark. What goes on? I'm 100% sure I'm missing something.
