GilligansIsland
- Joined
- Apr 14, 2010
- 138
I have some problems I'm trying to resolve with my new 7.4 michigan motorz (volvo) bogging out at above 2000, both under load and at the dock.
I had a fuel pump issue and along the way decided to get my carb rebuilt, just to eliminate some variables, since the carb was from my old engine. The reputable guy who rebuilt it said that my jets had been previously been installed backwards (the primaries were in the secondaries, etc.). So, the carb is totally redone and I'm expecting to see a boost in performance and fuel economy.
Problem is, now is when the bogging down issue started. It seems the only thing that was changed was the carb. Now, I also notice a vacuum leak. in the picture, you can see a nut with a hole in the center just to the left of the neg. term of the helix. It's a pretty strong vacuum and have no idea what's supposed to go here... or if it's supposed to be capped.
Now, if I cover the hole, I still get the bogging issue. I think I may still have a fuel pump issue but not sure... but I need to first solve this vacuum thing and then move on.
Thanks for any help.
