Re: Audio Alarm Q5I
Again, someone correct me if I'm wrong. I'm no mechanic. The buzzer will pretty much be dangling by wires under the instrument panel. About half dollar size and white on one side. It should come on the first time you turn the ignition on but will go off on it's own after a given amount of time or possibly after you crank the engine. I don't know of any in line fuses but there could be some, also there also sending units involved for different sensors. Here's what I've come across. Pull the tan and blue wire and touch it to a ground. If it doesn't work, the alarm is bad. If it does there's trouble elsewhere.
If the alarm itself does work you could ask this question in another section since the alarm is Mercruiser equipment.
