Audio Warning System
Mr. Phillips
My 2006 Thaoe boat has an audio warning system that goes off and the fluids arent low , its not runnin out , nor does it have low oil pressure. I need help if anyone knows what to do let me know.
ralphy670
Re: Audio Warning System
When does it go off? It should sound when you start it, but then stop right after.
rdhawk1950
The audible warning functions on three different sensors. High heat, low oil preasure and low drive oil fluid, this bottle has a float type switch in it . It is mounted on the front right side as facing motor. There is a high and low level on the resivour.The next time the alarm goes off unplug the wires to the drive fluid if alarm quits have bottle replaced.The wires are just below the tank. Be carefull the belt and pulley.
