Re: Automatic Trickle chargers
JB, by your question mark I guess you think it odd to have a "closed battery compartment" They really arent closed, a more accurate description is Vented Battery Compartment, thats the description in my manual. They are fairly common on bass or fishing type boats usually the carpeted boats with compartments all over the place for everything. Most are lockable as well for security. A very nice feature to have on a boat, batteries can walk.<br /><br />The manufactures design these battery compartments to prevent the build up of gasses. I have two such compartments (2 batteries) and both are well vented. If they werent you would have a potentially dangerous situation at any time especially when the motor was charging the battery. Im glad you pointed out the dangers of a closed battery compartment because even though I know mine is vented I shouldnt assume others are, also you wouldnt to place a battery in a compartment that wasnt designed for it!<br /><br />87, on the charger itself there should a warning to "Only connect charger in well ventilated area", the Pro units have this warning. If your compartment is anything like mine it is vented and you too will have to open the door/hatch to plug the unit in, and you will not be able to close the hatch while charging. This is new to me too but the compartments are designed for this and the dealer was the one to suggest the charging unit and they installed it. <br /><br />Hope this was informative.<br /><br />
