I've been doing some reading, and cant seem to find what Im looking for. So here's what i'd like to do.
One battery for starting the engine, running lights, guages, horn (21' Starcraft fishing boat, so this is no problem for one battery). One battery to run an inverter. NOW... I dont want to have a manual switch involved in this. What I want is that once the starting battery reaches a set voltage, say 13v, THEN my charging system begins to top up the second battery. IF the starting battery drops to say 11.5 volts, then the charging system automatically cuts the 2nd battery, and begins charging the starting battery again. Is there anything out there that does this? Can i build it myself using Diodes between the two batteries. Basically what im building is an if/or switch for 12vdc. Ideas?
Thanks
Stu
Thanks
Stu
