Wellcraft260
- Joined
- Jul 19, 2005
- 12
Hi everyone, I am repowering my 1994 26 wellcraft with a chev small block 383 stroker built for torque and it dynoes At 403 hp@ 5250 rpm. Torque is 455 @ 3250 so I believe it should work quite nicely mated to my VP SX-S outdrive compared to the stock 5.7 two barrel original VP marine engine. I originally had it built for my suburban to tow this 5000 lb boat but have decided to use it in the boat instead. My question is can I stay with the mild performance cam in this engine or should I change it to a marine specific grind? The existing cam is a Comp cams XE274H advertised duration is in. 274 / exh. 286 total lift is .490" both intake and exhaust with my 1.5 roller rockers and 110 degrees of lobe separation angle. The Comp marine cams have very similar duration and lift numbers but use a 112 degree lobe separation angle. My concern is reversion and my engine builder says he has built dozens of these engines for marine applications and has had no problems. They are a very respected machine shop and engine building facility here in Edmonton so I trust them but would like to hear from some of the very knowledgable folks on this forum regarding this issue. I have noticed that some of the regulars here are very generous with their time and knowledge and it is nice to see people giving up some of their valuable time simply to help others! Thanks in advance guys and keep up the good work.
