automotive coil on '80 merc 470 good enough?
montejw360
is an automotive coil on '80 merc 470 good enough? trying to troubleshoot a problem of the engine dying after 1/2 hour or so. can't get to the rest of the ignition parts until Saturday, maybe, but I can get the coil tonight and give it a go tomorrow night after work.
more on the problem here
thanks
firecapt13
Re: automotive coil on '80 merc 470 good enough?
I run a auto coil on my 4.3 and it works fine
Don S
Gotta love answers like that. Completely different engine and ignition system, but he uses one, so it must be ok for everyone.
EddiePetty
I have run an aftermarket auto coil in our '79 V-20 with the 470 for years now with no problem. Just be certain to purchase a 12 VDC EXTERNALLY resistor type coil as your ignition system already has a resistor element (wire). I would encourage the use of insulating boots over the primary connectors to preclude the chance of a spark from a dropped or dislodged object. And be cerain to maintaing the correct polarity of the coil.
montejw360
the bit about the resistor helps loads, thanks.
