Aux Trim Switch Wiring - 96 Force 40HP
67Johnson6HP
Picked up a Mom ON - OFF - Mom ON toggle switch to use as trim switch on motor. Wired it Blue-Red-Green. Problem is I used the Red wire on Down relay for the 12 Volt source and fried the Green wire on the switch when I pushed it down - Trim up worked. Guessing I used the wrong 12 Volt source. Trim up & down still works on front controls. What is a good 12 Volt source for this switch? Thanks.
